FTE Resonator
neverkickn
AR
Not sure I care for glass pack since those do burn out, but the resonator definately interests me, I need to measure and see if I even have 30" under the truck, BD brake takes up some room but may be able to relocate. FTE makes a muffler too so may think about doing a combo.
I just assumed that the mbrp muffler was glass filled. That is the other muffler that I have installed. The resonator is only 5 inch diameter so you can install it inline anywhere you have a 30 inch run.
TARM
bbbxcursion,
Wasn't it you that had that long thread last year where you went thru a ton of different configs trying to get the quietest drone free setup? If so why not link up that thread as I bet the info in there would be helpful and of interest?
sethc24
BC, Canada
So the resonator helped with the in cab drone?.
I have a 4" TB magnaflow system and in cab drone is absolutely ear ringing.
