Fuel leak help
dasboot
Gooberville, Ga.
I developed a fuel leak at the upper fuel filter housing.
it is coming directly underneath where the thing that mounts on the side of the housing shaped like a cross sort of next to the access plug. It is not leaking at any of the fuel line connections. that cross looking thing looks to take a couple of orings (via internet search)
is this common thing that need a gasket or new orings. What is this called.
until I get to the shop tomorrow and use a small mirror it is hard to tell for sure.
where can I find something that shows a good parts break down of that filter housing?
Thanks
dasboot
Gooberville, Ga.
ok it looks to be coming from the fuel pressure regulator housing.
looks like I might be doing an up grade kit.
are these known to start leaking?
Nic
Santa Fe, Texas
Yes its very common and more so on the 05-07 models for some reason. If you dont have it, get the blue spring update kit (which they should give you anyway).
Harley Strokin'
Northern Va.
Yea my 05 did the same thing, bought the blue spring regulator kit w/ the cover included and no problems since.
Sent from my ADR6410LVW using Tapatalk
