Fuel pump problem
Ok guys so I got in my truck today started it up and the fuel pressure gauge was fluctuating more then usual so I let it warm up go for a drive and it drops to zero. Went home shut it off made sure the gauge was hooked up and working right go to turn it back on the gauge is still buried at zero and my airdog 2 pump is not making any noise at all. Made sure all the fuses in the truck were good and that the power supply was hooked up right. Put new connectors on the wire ends. Checked the in line fuse. Made sure it was all plugged in and hooked up right. Everything looked absolutely fine and was hooked up still no power to the pump as far as I could tell no noise gauge read zero but the truck started right back up again and I was able to put her back in her parking spot. Can anyone help me figure out what's going on?
2001 ecsb 7.3, gtp38r, blank pedestal, ccv mod, reg. return, ad2 pump, gh tunes om a hydra, bts built 4r100,and more
2012 yfz450 bunch of stuff
Mesa, AZ
Had this happen to me once on my 6.0. The relay had failed. Truck ran but lacked power, obviously. Apparently the system is sealed enough that it will suck just enough fuel to run. Try swapping the relay out, or jumper it with a paperclip, see if you have fuel.pressure then.
Ok I will give that a try after work today.
Found it replaced it still no power to the pump.
Checked that too lol there was and it dident need reset but I finally got a tester and it is getting power so it burned up gonna have to send it out for a replacement.
79jasper
skiatook, Oklahoma
So the pump is bad?
This is why sd pumps are good. Can walk into any parts store and be on your way. Lol
Yes it is and I still have the stocker.
CarportMechanic
WA
If the stock one was good when you removed it buy another and build a dual pump setup. Will support most injectors out there.
Many people stay away from fass and airdog for our HUEI trucks due to the higher PSI we require. The pumps just cant keep up.
Yes as of now I do.
I was thinking about doing that how do you guys running dual SD pumps like them?
emev0l
1 stock SD pump will support up to 160/100's
Any of these 3 will support any injector you want
Aeromotive A1000
Fuelab 41401
Dual SD pumps
There's more to it then just dropping any of these pumps in, you'll replace everything from the tank to the heads.
I already have a driven diesel reg return and I just got off the phone with ad there sending a new unit be here in 2 to 3 days gonna give it one more chance before I switch since it's free under warranty but if it happens again I'll be switching.
Swaan
I've had a fuel lab on my truck for over 3 years not a lick of trouble
Good to know I already have one stock pump so I may just get another one and build a kit.
Magnum PD
VA
I built my own dual SD pump setup. With somebody's help. Can't remember who for some reason.
How much money you end up spending to do it yourself?
