Tank Selector Valve (Diesel Only) Component Testing Procedure
On the Selector Valve Connector, the terminals are:
Pin 1: Not used
Pin 2: 789 (BR/W)
Pin 3: 786 (R)
Pin 4: 673 (DB/Y)
Pin 5: 29 (Y/W)
Pin 6: 675 (Y/LB)
To Test the Rear Tank Circuit:
Briefly Apply 12V Power to Terminals 789 (BR/W) (+) and 786 (R) (-)
Connect Self-Powered Test Lamp or Ohmmeter to Terminals 29 (Y/W) and 675 (Y/LB): A good Switch will indicate Closed Circuit
Connect Self-Powered Test Lamp or Ohmmeter to Terminals 29 (Y/W) and 673 (DB/Y): A good Switch will indicate Open Circuit
To Test the Front Tank Circuit:
Briefly Apply 12V Power to Terminals 786 (R) (+) and 789 (BR/W) (-)
Connect Self-Powered Test Lamp or Ohmmeter to Terminals 29 (Y/W) and 675 (Y/LB): A good Switch will indicate Open Circuit
Connect Self-Powered Test Lamp or Ohmmeter to Terminals 29 (Y/W) and 673 (DB/Y): A good Switch will indicate Closed Circuit
Check that the source and return valve transfer between front and rear positions. NOTE: A brief “zip” sound can be heard when the valve transfers.
