dustinz85
I just bought a fuel bowl delete RR system, for one Im tired of buying that expensive pita filter on top of the engine :fustrate:. Anyhow, I already started my fuel system (planning on bigger injectors soon), I did the hutch mod in the tank (planning on maybe a 5/8 pickup) and rubber line to the stock fuel pump. I installed a filter housing between the tank and the pump (Baldwin BF957 Fuel Filter) i believe it is 12 mic. My question is, is the current filter installed good enough for a pre pump filter, and what are your guys suggestions for a filter after the pump still the factory one isnt going to be there anymore. I was thinking a BF1212 water separator with a filter. What do you guys think for type of filter? 2 mic/5 mic?
