Gagues not working right
1fastTRX
Which gauges? Dash or aftermarket?
Sent from my SCH-I535 using Tapatalk
shryack01
I got the yellow wire to constant power and the red wire to red with yellow stripe under dash it's a gray plug with 6 wires I think
webb06
Seneca, MO
Apparently you have the gauge power wire hooked to the light switch wire. You need that to a key on +12v source.
Then if there's a separate wire for them to light up when the lights come on then connect it to the light switch
1fastTRX
I used the ignition wire when I hooked my gauges up. Just poke around some underneath the steering column. The thicker gauge wires is where you should start looking. I can probably check tomorrow if you want for the color wire
