Dan
Hey! So I know there's another thread about gearing in this section but I didn't want to hijack that post so here I am starting a new one...
I need some help with figuring out what to do with my gearing, I have been struggling with the logic behind what different changes do... Ok so I'll explain what I'm thinking and hope for some constructive criticism!
Ok so I have factory 3.55 gears with 38" tires and (soon to be) 75mm/94mm compounds so that being said, fairly large turbos to get lit. Now I know a turbo charged engine needs load to light turbos and when I had the single 68mm, the turbo didn't even light till second gear. Now I'm going to mess this up but if I gear **higher**?? (Don't know if the term is lower or higher, but putting 4.10 or a higher ratio than 3.55) that means that my first gear is going to be even more useless as far as turbos lighting... Oh the joys of having a almost 4:1 first gear!
Now in my mind it's a catch 22...
Because having 3.55s with the bigger tires I'm not at all in the sweet spot on the highway.. Especially with that single turbo and now even more so (I anticipate) with the twins.. So I got my paper and pen out and the axle conversion online..
At 75 mph, with 3.55s and the 38s in 6th gear I'm revving 1575 rpm.
At 75 mph, with 3.55s and the 38s in 5th gear I'm revving 2025 rpm.
So now,
At 75 mph, with 4.10s in 6th rpm is at 1822
At 75 mph, with 4.10s in 5th rpm is at 2340
I think with the 4.10s at 1800 rpm that engine will make enough torque to pull up hills without downshifting.. That was my biggest issue was instead of torquing up hills at 1600rpm (cruise on) the 68 wouldn't light and just smoke untill it finally down shifts and then sits you back in the seat till it gets back up to speed then up shifts again and smokes, down shifts... Hunting for a gear till the top of the hill (Might have been a tuning issue I don't know)
I'm looking to improve my drivability with gearing and yeah I know it's gunna be tough with such a big turbo combo but here's what I have running around my head: I could stick with the 3.55s, and that will load up the turbos quite well but I would be counting on the high stall converter to get things moving off the line. And on the highway just run it in 5th and then at 2000rpm there will be no issue keeping it lit!
Or
Go to 4.10s and hope that 1800 rpm is enough to keep the turbos lit on the highway cause if the truck downshifts, well 2350 is decently high.. And as far as getting things going when racing I could look into starting in 2nd gear to load up them turbos..
I know I'm overthinking this! Just trying to understand! Thanks for any input!
So now,
Or
