GEM module
TitoBandito78
I bought my fuse block and gem from Ford. The Fuze panel is junk. It's so flimsy the panel flexes and shorts shti out while the truck is on.
The abs light will flicker like a bad vss but if you push on the fuse block it'll stop.
bluedge8
Champlin MN
If you pm me the part numbers I can check with tousley ford local to me, they are a nation wide parts house like sunrise ford
jimdawg185
Except that's just the fuse box with no GEM and likely will not solve the problem.
I'll try to do some looking. Been very busy and these kind of parts are stored in a place not easy for me to sort through. :doh::doh:
If Jim has the numbers off your GEM can you PM them to me.
sweet. thanks man. jim posted them up. which i could have done already. lol
bluedge8
Champlin MN
Is your truck:
4x4?
Pwr windows?
Keyless entry?
Esof?
If so the gem is $477 w/ $50 core retail and $365 w/ $50 core on a FTE discount, they have one in stock. There are 6 different fuse boxes, ranging from $252-417 retail. I didn't get too into the fuse box detail. If your interested call auto nation ford, White Bear Lake mn 651-484-8888
Is your truck:
4x4?
Pwr windows?
Keyless entry?
Esof?
it is not keyless entry but has everything else.
thanks for checking on that bud!!! ill try sumrise on here too if i cant come up with something else!
