Jeremyleggett07
Ok long story short- truck loaded down for the weekend... Rolled into throttle to get on to entrance ramp of freeway and before I hit the ramp truck died! Couldn't get it started! Doesn't even throw a code. I checked fuel bowl and filter... It was good....
I have updated STC fitting... Batts date code 3/11... Truck turns over but no start up. Got towed to a local shop- not diesel mech but knows a bit. ICP volt was at .2v so unplugged and still no start up. After so much cranking batts died and took FOREVER to charge. Replaced billet fuel cap with OEM since it lost some from there but I think it was not completely tight from checkin on side road. Only codes thrown was low inject pressure from reset fuel pump and ECM/PCM processor code..... No crank still. Left truck in shop till
Mornin! Any ideas!? Recommendations??
