Getting Rims/Tires + Keeping Stock Hieght
08IH6.4
Is it possible to fit 20x10 (-25 offset) Ultra Wheel Crushers with 35x12.5x20 MT BAJA MTZ tires?? I will install a 1.5" levelling kit if need, but I must fit into my garage. I will be taking the truck off road lots so I don't want any rubbing, but have lots of zip ties.
Lipka101
Maryland
35's will be too big with that wide of wheel and offset. Probably will rub with a leveling kit. Go with 33's. They are cheaper and will look better.
DWhite
Oklahoma
I have 35 12.50 20s on monster xd wheels with a -12 offset without rubbing and I'm at stock height. I think with that much offset it might run on the inner fender when turning but I bet you could trim or pull it back if you wanted to. I would probably run 1 Or 2 inch leveling kit if you can. But you can always try it and see if it fits then raise it some after.
01pwrstkr
Polk County NC
My truck is bone stock height. 20x10 RBPs -25 offset. 325/60/20 Nitto Terra Grapplers. According to the calculator that's 35.4x12.8. They rub on the inner fender a little bit (it's pulled back pretty far with zip ties). And it also rubbed on the bottom of the fender on the little metal lip that hangs down. I cut a little bit of that metal lip off and folded it back some and it doesn't hit it anymore. And you can't tell it's been "modified" unless you are looking for it. Here's a couple pics.
"3 can keep a secret if 2 are dead"
08IH6.4
Thank you! God, damn that's a nice 6.4!!! Cant wait to get them on!!! Looks amazing.
they will only require minor trimming to fit and the inner fenders pulled back. anything other than street driving they will hit the body hard.
eiorg9
it will work. I am running 35x12.50x20 and only have installed a leveling kit. When i back up hard left i get a very little rubbing but i cut the fender a little and now its perfect. i Also have a pretty substantial offset as well.
08sixfour12
Canada
DWhite, Can you post a pic of your trucks rims/ tires, I'd like to see a -12 offset.
thanks
