6.fast
So a few weeks ago i started my truck up and it threw a FICM low voltage code. now just the other day it was about 30 degrees out all night when i went to start my truck and i got these codes. V0105, V0306, and V0100. It also cranked for about 6 seconds and then i stopped. and when i tried again it started and ran rough for a couple seconds. After the truck has warmed up it doesn't throw any codes when i shut it off and turn it on. And just today the engine temp. was at about 112 degrees and it gave this code V0155 and the low FICM voltage code again. I checked the FICM and it read 48.5 volts and i checked the wiring harness for tears or wearing. So im wondering what is going on. Is it just cause its cold or is the FICM on its way out.
Its an 06 F350 with 118K miles and is all stock with an edge tuner that i just use for reading codes and keeping an eye everything.
