Glowplug wire colors go to which glow plug??
mikemcmac
Hi, disconnected wiring harness for ohms test on glow plugs. Found two bad GPs on drivers side... The two middle wires on the connector, and then one bad reading on the passenger side... The yellow wire.
Two questions.
1. Which glow plug correlates to the wiring harness wires on the connectors.
Do you do it by wire color, or orientation of the wires on the harness?
2. I need to know the orientation of the the glow plugs on each side of the engine.
1357 on passenger side. 2468 on driver side.
Which plugs are closest to the radiator for each side.
PS... Brand new member to the community. Any help is appreciated...
