Good single or duals ?
Raptorgabe
Am gonna upgrade the steering stabilizer wondering if I should just do a good single or a dual set up ? Are the dual setups actually worth the money or what do u guys think
UNBROKEN
I'm all about asthetics and you can't beat duals for looks....function is fine with either.
why not do a carli high mount? no looks change, only functionality
Black AOD
Ohio
I don't have a 6.7 but I mean the front end doesnt really change from a 6.4 to 6.7. I just did OUO's front truss that incorporates Dual SS. I used Fox 2.0's. I've seen a lot of Dual SS setups...I personally believe this one to be the cleanest installed one yet I've seen. It definitely did help tighten up my steering no doubt. I had a little play in my steering wheel before and barely have any now at all. Then again, the play itself is due to the fact that I need to replace my steering box and my drag link/pitman arm and tie rod.
Black AOD
Ohio
This is a good option too. I had the Fox Hi Mount kit, however on my truck it rubbed a trans cooler line which made no sense to me at all....but the hi mount kits are good options too.
Jacob @ No Limit
Indiana
I love my PMF dual setup with the King stabilizers. Handles amazing. Best driving truck I've ever been in by far! Hell it drives better than most cars with that and the Helwig sway bars. My 37s aren't balanced at all and I can't feel any shake or vibration at all in the steering.
Jomax
Arizona
My problem with PMF is I lost some steering. The shocks would bottom out before the axle stops, making my turning radius bigger. That, and the shocks never worked right. They seemed bad, I could barley move them even with my weight on them. Called PMF and got a "we never had that problem in both accounts". So much for help... These were with Fox 2.0s.
They are now sitting on my bench and will be selling the whole kit.
jcain
Doesn't seem plausible. I run the same 2.0s on my wide trac and have more turning degree than a standard super 60 and I don't bottom them out.
Raptorgabe
That's where I'm at ! Couldn't get my tires to balance since the tires are used and now wider so i have a shake in my steering wheel also
Jacob @ No Limit
Indiana
Mine have plenty of room left on the shocks at lock to lock. That's strange. I love everything I've ever bought from pmf
Raptorgabe
Yeah pmf has badass stuff !! I like the look of the high mount Carli ! Would that be better than the dial bilsteins ? About the same price
