taterthedog
My old green 7.3 is acting up again. Just pulled it out of the snow bank last week and been using it a bit. It was parked last fall when it started to refuse to stay running on a cold start. It would start fine and then after a few minutes ICP would dwindle down and it would stall. After waiting a few minutes it would start up again and repeat. After it warmed up enough it would stay running and run normally. I can to the conclusion that the 15w40 was too thick in the below freezing temps and was taking along time to get back to the hpop. Base oil pressure stayed good. Today coming up from the cabin, it started to loose ICP pressure under load and lack power. It was acting similar before and I replaced the IPR and it was better.
