jacobdewey
Has anyone tried it yet? I would think it would work well to provide great top end power and somewhat mellow bottom end, to help the rods last a bit longer. I also like the fact that it's a ball bearing turbo with a water cooled center section.
4094R Specs:- compressor - 67.8mm Inducer 94.0mm exducer w/ .72 A/R Compressor Cover (4 inch inlet) - turbine - 77.0 mm wheel diam. .85 AR T4 (3 inch outlet)
Anyone with much experience with this charger?
The other thought I had was a 4088R, a little smaller (63.5mm inducer), and is said to spool a bit faster.
Input would be great, as I am thinking a meduim sized single could be alot of fun, and I will likely see one in my near future.
I had a s366 on my Duramax, and would like something similar, but more reliable.
