I have a new, unopened rebuild kit for a gtp38 turbo. $55 shipped. Kit includes: 1-Thrust Bearing 2- Heavy Duty Journal Bearings 1- Thrust Collar 1- Compressor Side Piston Ring 1- Turbine side Piston Ring 1-Compressor backplate to bearing housing Seal for 99.5-03 turbos 1-Compressor backplate to bearing housing Seal for 94-Early 99 turbos 1- Compressor Housing O-ring 4- Pedestal O-rings 4-Bolts Grade 12.9
