Gtp38r?
lightning95
Smoked the stock turbo last night and looking to do the upgrade.
I was thinking KC turbo but know found one from XS Power that has similar mods and 4 year warranty.
Haven't heard much feedback on either.
What say you?
Hell, skip that. Do some gtxr billet compounds. Why stop at 4 grand to put a dinky turbo in. May as well spend 12 or 13.
Gainesville Ga.
Call kc, talk to em, and go from there, the 38r is good, the kc should be better
06-6.0l, CCLB 4X4, studded, reworked heads, egr gone, cab reroute, blue spring mod, 6.4 banjos, updated dummy plugs, stand pipe, and stc fitting; New oil cooler, New ipr, New icp, atlas 40 FICM, powermax turbo, and Geerhead tunes, 325/65R18
David N
Eastern NC
I love my 38R. Ran it for many years now and over 50k miles. I just upped my 250/200's to 350/200's and my truck runs very well. A couple weeks ago I was running 8.0's in the 1/8th.
For the money and simplicity you can't beat one. But if you have 3k laying around, go with a t4 mount.
lightning95
Thanks guys I need simple and somewhat affordable. This is the wife's daily I broke running on the race tune and 33# of boost.
I may run some 160 sticks later. Gotta be careful with the powdered rods.
I'd love to go full retard on a build but the 7.3 is not the one to do.
Turbosuzuki
Louisiana
Can I ask why you were hot rodding the wife's daily ? Just kidding lol.
dadada
Indiana
Easy, somewhat affordable, 160 sticks and pmrs? I'd go the 38r route. Direct bolt on. Easy enough and a good proven turbo.
emev0l
Keep the 38r at 36 psi and watch your EGT's and it'll last a very very long time.
lightning95
Thanks for the input guys. I just ordered the KC38r and now have been looking at intercooler boots. Leaning towards Riff Raff.
Likewise....
I think some of you guys hooked your 38r up backwards or missed an upipe connection to realize your claims as stated.
79jasper
skiatook, Oklahoma
I'm not saying t4 isn't good.
Obviously it's the best choice.
But does everyone "need" it?
cjfarm111
If you do uppipes and a 38r your 1700+ into it. So for $200 more you can have a t4 with a rebuildable turbo with many options now and down the road. I wish I woulda gone the t4 route a lond time ago instead of spending money on the 38r
Justin@DP-Tuner
Good point here. I run the 38R myself, but only because I have to pass smog (visual check) here in CA. After a set of bellowed up-pipes and a 38R, you are somewhat close to what you can get a T4 setup for. For E99 or OBS guys, the T4 route is a no brainer if they ever plan on any injectors bigger than stock.
I always see guys saying that the T4 setup will run $3000-$4000 too. I am not sure where they are seeing those prices, but you can get that setup at a significantly smaller cost. We sell it for much less than that... https://www.dp-tuner.com/ford-power...pgrades-39/turbochargers-1/bws300sxe64-5.html
79jasper
skiatook, Oklahoma
Some pretty valid points.
Do hear a lot say they don't like the 38r, because the noise.... lol
