Hate to do it...
Hotrodtractor
Mingo, Ohio
Ladies and gentlemen - this is a real deal built and functional truck - it takes a TON of time, money, and effort to put something like this together and that is why you don't even get to see them very often, let alone have an opportunity to purchase.
907DAVE
AK
Thanks!
There was no expense spared on this truck, even on the audio system.
washingtoncoastie
currently, kodiak, alaska
Dave, are those lightforce lights on the front? Never saw them before i came to alaska, lots of guys run them up here. Been looking to get some for the excursion. They are not cheap. And pm me a price please, might have to see if i can sell my ex!
907DAVE
AK
Naaa...those are cheap ProComp lights with 130w bulbs. The Lightforce's are bright, but not worth the $$$ in my opinion.
But when you spend 8 months out of the year in the dark, good lighting is a must....especially with all those pesky moose running around....lol.
Derek@Vision Diesel
Canby, OR
You make where you live sound awful... 1500 miles of ice, moose everywhere on the road, never gets light, and motors never last. Alaska is hell haha
907DAVE
AK
Its not for everyone....
But for those who enjoy their space, its heaven.
907DAVE
AK
Yeah, I sometimes wish I was closer to the states.
OH CANADA!
David S.
shame to see this bad boy up for sale. Someone will be very happy with this
907DAVE
AK
Okay guys, here's a better breakdown of what has been done to the truck.
Engine:
Block Filled to 2" from deck (have no cooling issues, oil temps stay normal even when towing 14K)
Crank turned .010 under on both rod and main journals
Clevite 77 bearings
Main Girdle and ARP main studs
Crower Billet Rods
Mahle pistons machined to match deck height and valve reliefs cut to accommodate cam
Rotating assembly balanced to 1 gram
Heads are ported and polished, new cups, bronze valve guides, hard seats, Clevite 77 valves, and are machined to accept the FireRings with a 25RA finish
WOP cam
WOP valve spring kit installed at ~1.86
WOP FireRings
SmithBro's chromoly pushrods
Stealth twin HPOP's
Dieselsite reservoir spacer
Dieselsite 203* thermostat
Dieselsite coolant filter
New oil cooler
Air:
TN 88mm ball bearing primary
TN 66mm ball bearing secondary
Both stages intercooled
Both stages gated using RG-45 gates
TN wastegate controller
AFE Pro7 filter
Fuel:
Swamps 300/200% hybrids
Fuelab 42401
ITP 5/8 pickup tube
Aeromotive Hex Drive regulator
4 port feed using 3/8's lines
Transmission:
Suncoast billet input shaft
Suncoast clutches
Transgo Tugger 2 kit
Banks billet triple disk converter (stock stall)
Stereo:
Kenwood DNX 7100 HU with GPS navigation
Alpine H700 Processor
Focal 165K2PUV (components)
Image Dynamics IDQ12V3 (sub)
Sundown Audio SAZ-1000D (1000 watt sub amp)
Sundown Audio SAX 100.4D (100X4-channel speaker amp)
Custom sail panels tweeter pods
Custom center consul sub box
Custom amp rack with fiberglass/carpet fascia
Kunukonceptz Krystal Kables
All 4 doors sound deadned inside and out
Lighting:
Projector HID conversion
4 foglite's
KC backup lights
ProComp driving lights (135w) on custom light bar
The rest of the truck:
05 conversion
Gooseneck Hitch
Firestone Air Bags
Truxedo Slim tonneau cover
Diprocol EGT, boost, and trans temp gauge
Autometer boost (primary), and backpressure gauge
Aeroforce ScanGauge
100 gal auxillary fuel tank with transfer pump
Greddy turbo timer
140 volt IDM
200 amp alternator
907DAVE
AK
If anyone's interested, I tallied up some of the extra's on the truck:
Engine:
Clevite 77 bearings
Main Girdle and ARP main studs - $1000
Crower Billet Rods - $2,700
Mahle pistons machined to match deck height and valve reliefs cut to accommodate cam - $1200
Heads are ported and polished, new cups, bronze valve guides, hard seats, Clevite 77 valves, and are machined to accept the FireRings with a 25RA finish - $500
H-11 head studs - $795
WOP cam - $750
WOP valve spring kit installed at ~1.86 - $500
WOP FireRings - $500
SmithBro's chromoly pushrods - $225
Stealth twin HPOP's - $1200
Dieselsite reservoir spacer - $225
Dieselsite 203* thermostat - $35
Dieselsite coolant filter - $100
New oil cooler
Air: - $7000
AFE Pro7 filter
Fuel:
Swamps 300/200% hybrids - $2250
Fuelab 42401 - $500
ITP 5/8 pickup tube - $50
Aeromotive Hex Drive regulator - $200
Transmission:
Suncoast billet input shaft - $300
Suncoast clutches - $500
Transgo Tugger 2 kit - $150
Banks billet triple disk converter (stock stall) - $900
Stereo:
Kenwood DNX 7100 HU with GPS navigation - $500
Alpine H700 Processor - $250
Focal 165K2PUV (components) - $700
Image Dynamics IDQ12V3 (sub) - $280
Sundown Audio SAZ-1000D (1000 watt sub amp) - $280
Sundown Audio SAX 100.4D (100X4-channel speaker amp) - $320
Kunukonceptz Krystal Kables - $50
All 4 doors sound deadned inside and out - $200
Lighting:
Projector HID conversion - $200
4 foglite's
KC backup lights
05 conversion -$1300
Gooseneck Hitch
Firestone Air Bags - $300
Truxedo Slim tonneau cover - $450
Diprocol EGT, boost, and trans temp gauge - $250
Autometer boost (primary), and backpressure gauge - $80
Aeroforce ScanGauge - $200
100 gal auxillary fuel tank with transfer pump - $500
Greddy turbo timer - $100
140 volt IDM
200 amp alternator - $200
Total : $27,440
Add that to a truck that is worth 14K....
If someone wanted to buy this thing and part it out, that would turn a real nice profit(8k-10K)!
UPINSMOKE
Dundalk, Maryland
Engine:
Clevite 77 bearings
WOP cam - $750
New oil cooler
Air: - $7000
AFE Pro7 filter
Fuel:
Fuelab 42401 - $500
Transmission:
Stereo:
Lighting:
4 foglite's
KC backup lights
Gooseneck Hitch
140 volt IDM
Total : $27,440
So you're asking 41,000???
