Head stud help
Pizza pig
MD
synthetic oil and rev x will only be a band aid fix for so long. I got another 30k out of my injectors before stiction came back and didnt work any longer and then it was time for injectors... but now as a preventative measure I use rev and an 5w40 synthetic at every oil change.
Warren diesel can rebuild your injectors for about the price of two ford remans btw
Dieselroller
baytown,tx
Ok it finally trew a code! Ficm operation? This just started when I put the extreme street tune on it from innovative. Any ideas?
cfdeng7
CT
First thing I would do is check ficm voltage. Idk what you have to scan for codes but many scanners can read ficm voltage. If not there is a way to measure it with a meter across 2 bolts on it. If u google ficm voltage test or something you should find it.
