Head stud time! Any tricks? Pics of injector crud.
lariat 7.3
I'm confused hahaha, where's one of the veterans when you need them
Sent from my SCH-I535 using Tapatalk
lariat 7.3
Which torque process did you finish up with, so far I've been going off the top one torquing to 90 or so
lariat 7.3
What torque pattern should I use for the final, I've been going by the top one to 90lbs on the first pass, then the directions say do a totally different order for the final pass
bigfords
I did:
1. 95
2. 110
3. 125, then went over them again. I see they say to do a different pattern for the last sequence, but I do doubt that it matters. I did the sequence they had in the instructions, which basically goes by rows instead of working from center to the outside.
bigfords
So for the first 2 sequences I did the stock pattern ( which they have in their instructions)
lariat 7.3
Well she's back together,16 hrs straight. Any tips to get the motor mount bolts lined up? Or it doesn't matter?
lariat 7.3
They did but didn't line up with the originally location, oh well bolted it up
bigfords
Just leave them loose, start the engine, and put the trans in gear to rock the engine back into place.
