isootmypants
H-11s. Had 600 hp set up for 10k, then had motor apart again, reused them and have been running another mid 600s setup. I'm getting Manley rods and girdle, and shooting for 800. Best bet is to get new studs correct?
Can't you just measure them to make sure there not stretched?
800 hp on stock gaskets? TJ I would be getting fire rings if I were you and then just reuse the studs. I'm less worried about the studs and more worried about the gaskets.
I have a set of studs torqued onece for sale if your interested. H11
Oringed heads it is. Anyone use those extreme studs yet? Jw
