Headlight adjustment
caladash
In A House
Apparently my headlights are not adjusted properly because i keep getting flashed and I feel like a goon asking it but how do I properly adjust them? Its been a while since I had to do headlights. My apoplogies if this is in the wrong area.
Stroken7.3
Harrisville, UT
When I did mine I pulled my truck up to the garage door and lowered one side then the other to match. I just adjusted them enough so the beams would hit the road and the driving lights fill the gap between the truck and headlights, Hope this helps.
Tree Trimmer
pull your truck right up to the garage door, bumper as close as you can get to it. take two pieces of black tape and put them in a cross in the center of each head light on the door. back up about 20'. adjust your high beams to the center of that cross you made.
done. when you dim, the beams will point down, and highs will point straight ahead.
it should go with out saying, thats when you back up, it needs to be a flat surface.
