Towerguy
For sale are Hellwig front and rear sway bars for 4wd 2005-07 models although rear sway bar may fit other years. Front sway bar is Part #7676 1 1/8" diameter and rear sway bar is Part #7693 1 1/4" diameter.
Be advised that the front sway bar does not play nice with large diameter tires. The 90 degree bends just outside of the bushings are a little farther outside than the stock bar and large tires rub aggressively at the corner. Even the factory tires for 20" rims will rub it some, I believe they are just over 34" tall. It may not be an issue with shallow backspaced rims but I'm running factory rims which are backspaced almost 6".
The front sway bar includes saddles and bushings, $115 shipped.
The rear sway bar includes bushings, hardware to attach bar to axle, end links, $150 shipped.
