Help deciding on turbos
Rpbobby492
I currently have a s366 installed also have a s488 new in box cant decide on set up I was going to run the s366 as a high pressure and s488 as low pressure turbo but cant decide then I had another idea of running a big single I dont think it would spool, should I run triples and 2 s366 turbo to spool the 88 or running 66 then get a 72 then use the 88 to spool the 72 I haven't seen that done before.:angel: I will be doing this within the next couple weeks I'm installing arp headstuds, 300cc/200% rcd injectors, fas 220gph lift pump, a custom regulated return and a zex nitrous kit. Current turbo specs 66/74/.91 88/96/1.32 let me know what everyone's opinions are thank you
shmoozer
Hang the 88 out in front and run it. You’ve got enough fuel for it.
Mesa, AZ
What shmoozer said, run the hell out of it withthe 88 out front, should be a,blast
Rpbobby492
Thank you also just ordered 2 tial 44mm wastegates to attach to my uppipes they have 25psi springs hope it all works out for me
Rpbobby492
The block is all stock with 220k miles there will be a build in the future I might try a mild tune to start
