Help! Pulling motor right now.
ford141
I'm just about to pull my motor out but I can't get to the torque converter bolts. A standard socket is too short and a deep well is too long and hits the oil pan. Do I have to take off the oil pan to her the torque converter bolts off?
ford141
What do you mean? I'm using a 3/8 ratchet that has a flexible head, but it still won't work.
08BIGRIG
WI
Get some mid length sockets. That's what I use and have no issues with fitment.
Sent from my iPhone
-Jerry Bruley-
ford141
Never mind, I just found something that works. 1/4 inch drive 14mm with a 1/4 to 3/8 adapter= just the right length.
7.3powerstroke00
Brownwood
That must be a bad a$$ 1/4 drive adapter, some other vehicles I've worked on inwas worried that a 3/8 was gonna snap gettin TQ converter bolts/nuts loose!
ford141
I didn't know there was a second inspection hole above the oil pan. Got all of them out, didn't break the adapter either. It's a Lisle adapter I picked up at one of the tool dealers at a swap meet. They didn't seem all that tight to me.
I think I'll get a mid-length socket to put it back together though, just so I don't snap the adapter.
2wd-fire
This is exactly what I use every time
ford141
My heads were already off, so I just turned it with a wrench on the front balancer bolts.
