http://youtu.be/RGk0xZ422to
Just got truck a few weeks ago. 2012 cc sb with 110,000 miles on it. Trying to diagnose front end noise. Mainly when I am turning slightly left I get a very audible fast clunking/rumble. My initial thought was it was beginning stages of death wobble. The noise definately is coming from front passenger corner so tonight I jacked up that corner and started investigating.
I have zero play in the wheel when grabbing at 12 and 6 and push, pulling and twisting as hard as I can. Grabbing at 3 and 6 yielded essentially no movement as well. There was a slight click that sounded like it was up at the box. Definately not enough to induce death wobble I don't think.
So next I went to check u joint play and to my suprise the U joints seem very solid but there seems to be a lot of play out at the hub/bearing area. I posted video below where you can clearly see what I believe is the inner race wobbling all around. Would you guys say I'm in need of new hub/bearing assembly? Pretty sure this play is allowing u joint to flop all around at certain speeds and steering angles causing my noise. Thoughts? Recommendations? Best place to buy parts?
Thanks in advance guys.
