Silver6
Ive had an issue ever since the injectors got put in, so this leads me to believe its an injector stuck open, but you guys know a lot more than me. Truck was idling crazy after injectors, wound up being programming. Got that fixed. Truck was blowing white smoke after cranking (somewhat of a hard crank) even when 80*. Tested FICM, it was shot. Got a 58v from innovative. Still, when I crank it up in the mornings, and itll be 75-80*+, it is rough, and blows a considerable amount of white smoke. I can let it warm up for 15 minutes or more, and it will still take another 10-15 minutes of driving to get the white smoke to go away. After that, truck seems to run fine. Any help is appreciated. Just want to know if I need Jess to send me a new injector, or what I need to do. BTW, 190/75 injectors. TIA!
