POWER-STRUCK
read!! click the link!!
did you do this?
we can get very technical if you like! but.. if the mechanic cannot give us exact test results a conclusion can not be reached!
otherwise you are playing parts til it starts!
just because a part is new does not mean that it tests good.
here is a link for a diagnostic guide and if the tests are ran correctly you will more than likely stumble across the problem. print the sheet and do all the tests without skipping steps, write exact test results on the sheet
http://www.motorcraftservice.com/vdirs/vehicles/diesel/schematics/05_Diesel_Performance_Sheet.pdf
did you do this?
