I will be installing one of these in my truck in the next few weekends
UBG-16
I know it's a little overkill but the price was right.
I will be able to monitor.....and questions are in red
1: outside air temp___________not sure the best place to locate this probe?
2: coolant temp____________________sending unit located in coolant filter housing
3: lube oil presure__________________ where do I put this sensor? thread and pitch of the hole?
4: EGT both banks__________________1 probe in each manifold
5: fuel pressure____________________sending unit post filter on the bowl
6: HPOP pressure___________________run this off a t or y at the ICP sensor?
7: EOT____________sending unit in the top of the HPOP?
8: Transfer case temp___________Sending unit in the fluid drain hole?
9: front diff temp_____________Drill and tap?
10: rear diff temp_________Drill and tap?
11: transmission temp_________going to keep the Autometer in the port and add a sending unit to pan
12: Batt voltage____________at the batt
I will keep my pillar mount with EGT, boost and tranny temp, this will a supplemental/ troubleshooting aid as well as an overall engine condition monitor.
Any help with the above questions is appreciated...comments as well.
UBG-16
