DieselMater86
2003 with 211k auto
Truck didn't like the blue spring so took it out and put stock back in and took negative battery cables off for ten minutes to clear codes. Now two days later truck runs horrible has no power on flat ground barely make up hills. I have to go 3/4 throttle to pick up speed after about 40 mph sometimes. The truck starts fine did this morning at 24 degrees a little rough idle but leveled out fine. Start down the road and builds boost fine up to 12 psi but roll the window down and turbo sounds choppy. But sitting in park or neutral sounds healthy no shaft play either.
Heres the code my edge evo is pulling:
P0261
P0282
P0603
P1000
I know what they are and have tried resetting by pulling cables again but no good they obviously come back.
I'm leaning toward ficm, injectors harness,or 1 and 8 have finally failed.
I just changed both fuel filters also.
I have read 03 should have a 7 lug ficm but mine has a 4 lug ficm.
Any ideas or just replace all 3. I was waiting on taxes and going to 175/30s.
My edge shows no lower than 48v while cranking at cold weather, but don't like the fact my battery voltage is always around 13.8v to 14v while driving under a load or higher rpm it will hit 15v.
Any other info you need just ask, if I can do something with my edge to find more please tell me as I'm still learning it.
P0261
P0282
P0603
P1000
