Sounds like the same thing that happened to me...CPS is what it was
Sent from my DROID RAZR HD using Tapatalk
Crawl under the center of the truck its by the harmonic balancer. Ford pn F7TZ-12K073-B
Thank you man , i drained fuel filter and it started and is driving but now it shows ABS light is on ?
did it just up and die like you turned the key off or did it chug and stumble then die?
CPS won't stop it from cranking, just from firing the injectors.
*knocks on wood*
I was actually laughing last night, I went through my truck, I have 4 spare CPS's, lol, one BW, 2 OEM Black, and an OEM Gray.
Best part is I took the 10mm socket wrench out to use it the other day...and never put it back. So *IF* I have one fail.... I can't even put one of the 4 spares in, LOL
:lookaround:
are the black ones the original black ones that came in the trucks from the factory?
did you replace cps?
*knocks on wood*
:lookaround:
