Bad_company
- Joined
- Feb 6, 2014
- Messages
- 84
- Reaction score
- 0
04 6.0 big fuel leak from driver side after studs. Checked banjo bolts check under pressure regulated and top side of upper filter housing... Seems to be coming from down low. Checked fuel line fitting that run by the head and they are dry... Running down across engine cross member and down the oil pan... Where the F@#& could it be coming from?
