fulton327
I have a 05 350 with a 6.0 and Im having a high egt problem. I just put a new turbo in it I had buit by Turbo engineering corp. Its pretty much the same thing as a powermax ssx turbo. I have a bunch of other mods head studs, Airdog 2 set to 60-62 psi, Fuel cross over, Stage 1 fuel feed, Aem brute force intake,Cfm large mouth intake and all 3.5 tubing going to and from the intercooler. Innovative tuned ficm and Im running the xtreme street tune by them also. But still running stock injectors. When i had the stock turbo in the egts where not to bad cruise was 500-600 deg at 65mph now im 600-700 at 65mph. Now at part throttle around 12-14 psi im already hitting 1100-1200 deg and my snow system (50/50 mix) has to kick in to get the egts back down. I cant even go full throttle with it right now I feel like it would probably melt down my turbo if i tried. With my stock one I could go wot and my egts with the snow system running would stay under 1300deg. Im at a loss. Im not blowing black smoke its actually pretty smoke free. Anyone have any ideas or suggestions ?
