3brorce
- Joined
- Jul 27, 2011
- Messages
- 3,122
- Reaction score
- 0
The truck already has a Barder 73mm low pressure. Throw a 59mm high pressure or scrap the compounds and go s468 single? No plans to add fuel.
add a larger hp turbo. Frees up about 40hp with no lack of drivability or increase in smoke.
A gate is helpful but not a mandatory requirement. Make sure you run good tunes like gear head though.No need of a wastegate if do so? Up pipe no longer has egr provision so cannot put a gate there.
I had great luck with the Rudy's one. Bought it from MidwestWhich 59mm would you suggest? I would get a Barder but he is no longer building chargers. I see Rudy has one now.
Crap I misspoke. I meant RCDLooks like Midwest only sells RCDs chargers now? Unless you are talking a different Midwest.
I have been in multiple trucks with singles. Meh was what I came up with. I personally want the truck to respond instantly and be clean while doing so. I couldn't stand having to drive around the turbo.Have you ran a single? Im honestly not too worried about drivability and this truck barely tows anything ever.
Same as yours, barder 73What for atmo were you running with the 59 hp? Bigger comp side or exhaust side as well?
YepI appreciate it.
Stock fuel? I had a dual k16 kit for it but I sold that couple years back haha
Why drop drive pressure? 50psi boost is 60psi drive pressure.
I would max the factory ebp sensor at 72psi all the time until I gated. Who knows what it got to. When I gated it down to 65psi, my overall boost came down from low 50s to 48 psi and the truck made more power. I will say with no gate, stock hp turbo and 72 atmo, the valves floated and there was position contact.With a 59/73 that have nothing done turbine wise? No need to gate?
