Vader's Fury
:whs:
Most def. get a timer. These heaters are high wattage and will suck some power if left on for a long time. Set it about 2-3 hours before you fire it up, or even pulse the timer say every other hour for 15-30 mins if its really bad out. Oh also make sure to get a thick extension cord, again its pulling quiet a bit of power.
I forgot what the specs are on the heater element, but it is big like I said. The timers can be had for cheap, if you can hook it up inside some how... I have an electrical outlet that is outside, but has conduit inside and I just screwed/connected an electrical plug to it and plugged it into my timer and then into a box in the basement.
