How To Determine If A 6.4 Has A Larger Atmo?
Powerstroke Man 6.4
if the motor is out, absolutely. i didnt see anything about a motor coming out.
I would do it all at once to save money on labor..... But hey, wtf do I know?
Retort?
i would do the cam well after a built transmission.
That's the beauty of it... It's not!
Lol I'm just fu**ing with you guys..
Unless it is?...!
Nah the motor not coming out (unless it has to) just trying get some random info LOL.
Stroked777
Casper, Wyoming
We did the cam cab off, took the trans out, I still have a completely stock trans
Egts are about 100-150 degrees lower across the board and my boost has dropped from maxing at 52 to 47psi that's because it's moving more air but I have stock turbos
TD-5
British Columbia Canada
pull off your cai and measure the inlet of your turbo, I think stock is 65mm
Digital mic, Quick and easy on the LP.
Stroked777
Casper, Wyoming
Did your back pressure drop with that cam as well Austin?
Hard to tell never really paid much attention to ebp before I got the work done. Part of me wants to say no because they said the cam profile is designed to drive the turbos harder , it' moves more air thou
