PatriotHauling
Warning: Do not start a tuner war in this thread. This video is for instructional purposes only. You may ask questions but do not flame any tuning companies.
http://www.youtube.com/watch?v=KwLZAfNfddI&feature=autoshare
Get you a long extension and a 10mm swivel for the pcm connector. Saves alot of time and you dont have to climb over in there! I also like to cut a big enough hole in the plastic so I can remove the chip without pulling the pcm for when you want to send it off for updates. Just my 2 cents.
Would disconnecting the batteries during a chip install be the best way to prevent any electrical damage to the PCM? or is leaving the keys out of the ignition good enough?
Dont know if that would work on mine.. I have a bunch of electrical crap in the way. relays and wiring harnesses and what not.
One thing, I always throw a piece of duct tape over the chip to make 100% sure it CANNOT come loose. It has happened.
I like the idea of cutting the hole big enough to remove it without taking the PCM out. And realistically you should focus in more to show what a clean terminal is because: If you dont clean it properly the lacquer thats on there gets stuck in the chip so not only do you have to take everything back apart because the truck wont start etc you now have to clean the chip out very carefully and its a PITA. However you can clean it too much and now you either get it re-plated or throw your PCM in the trash and get a new one.
Who made this video? Curious why at 2:43/44 the chips used in the video change? Might be just an editing snafu...
