How to make 600 - 700 RWHP - 6.0L
046.ohBills
Middle Georgia
Posting in this thread because it seems most accurate(hopefully someone sees this) what kind of numbers is the bottom end of our trucks (6.0 psd) seeing with a stock bottom end holding up to?
this is a how to thread. start your own in 6.0 performance...
KCTurbos
There is a local shop here in AZ called Dieselmore that installs a lot of our turbos. They recently helped a customer build a rig... he was hoping for around 550-600hp and still wanted to tow heavy. His username is 6.0 tech
They decided on 190/30 + our KC 64mm stage 2 turbo with a little water meth. It took a little while to get the tuning dialed in (I think he was running a FICM tune). But now he tows max weight with ease and is making impressive power.
Time slips put him at about 615hp
ccsb 7630lbs
12.6 @ 106mph
Mesa, AZ
Thank you for the help on the selection of turbo and injectors Charlie, between you and Chris and Corey, i am very happywith the setup.
And by yhe way its a long bed, not short bed. :)
03cody
Bethany Illinois
ccsb 7630lbs
12.6 @ 106mph
Where did he get his tuning from?
Mesa, AZ
I forgot to add as well that idp's ficm tuner was set to performance on the strip, as i wssnt too worried about smoke.
powerstrokelyfe
Question for you guys. Would a stage 3 68mm VGT paired with 250/100 MM hybrids break 700rwhp ? Will the 250 hybrids hold ICP safely ?
KCTurbos
250/100 hybrid should hold ICP. It is also plenty of fuel for 700hp. Paired with a good 68mm vgt should push you above 700hp with a good running truck and good tunes.
BUT... 700hp is not an easy feat. Even with all the right parts you need to make sure the truck is in tip top shape. Gotta hold fuel pressure, ICP, no boost leaks, no exhaust leaks, etc. I have seen all the right parts come together on a truck and not run right... usually because something small was wrong.
Jomax
Arizona
I'm daily driving 250 conventionals..... Trucks about 750hp on fuel and 900 on spray. It's a fun setup with just a 369
That thing still in one piece??
swinky
Eastern, Nc
powerstrokelyfe
Great to hear. I am assuming your running an aftermarket HPOP to keep up with the conventionals correct ?
