grab the slave on the tranny and turn 90 degrees and pull it out. Go under the dash and pop the rod off the clutch pedal. Then go under the hood and twist the master 90 degrees and pull out. Pop the res off the cowl and feed it out. Then feed the new one in. do the opposite of removal. Once its all in push the clutch and it will break the tabs on the slave and you are good to go. Done mine three times. let me know if you need anymore info.
cheers
