Power Strokes
94-97 Tech
HPOP Gaskets Leaking - \
[QUOTE="Optimator82, post: 1513960, member: 26374"] The lines need to be rated to handle the constant heat cycles and pressure of the hpop system and standard hydraulic line is not. I'd be hestiant that the ones found on eBay unless OEM are made with suitable rated hose to be used on these trucks for the hpop system. I would look at getting a set from Corey at CNC Fab. They are priced less than OEM ones from Ford and they are made with the proper rated hose. [/QUOTE]
B-Code VOP
Latest: Charles
Today at 5:57 AM
7.3 Aftermarket
Latest: Charles
Yesterday at 9:41 PM
7.3 Aftermarket
9
Latest: 99fordman18
Yesterday at 12:02 PM
Sunrise Ford Parts
Lower coil spring pad bolt
Latest: KBMKVIII
Tuesday at 7:14 AM
B codes vs hybrids
Latest: Charles
Monday at 9:54 PM
7.3 Aftermarket
Jonnylu
ToMang07
Power Strokes
94-97 Tech
