pontiacross
- Joined
- Jun 12, 2011
- Messages
- 410
- Reaction score
- 0
I am running a bts dual HPOP setup in my puller with a stock 17degree pump on the bottom and a dt466 pump on top. after putting my injectors back in I was running it to get all the air out of the system and blew a high pressure line after reving it up a little bit. after replacing the line it would no longer build ICP. after some testing I found the 17degree pump bad and threw in a 15 that I had laying around to get it going. after talking with several people I think the relief valve may have gotten damaged after a pressure spike caused from the engine running in default mode since the check engine light was still on for "unable to buld ICP at cranking".
long story short the 15 is not keeping up, I have heard you can repair the relieve valve but cant find any info on how. dose anyone know how to check and or repair?
