silverpsd_06
My buddy took the hpop out of his 94.5 power stroke and re sealed it also took the non serviceable plug out:doh: now it won't start tried for a little bit when we first got it back together even ran for about a minute then petered out. Supposedly he has checked ipr duty cycle through his multimeter and says 8.5 looking at icp tommorrow. Cps is a known good one, after it died it would sound like hammered ass on the number eight cylinder while cranking has wts start light. Anyway to check idm voltage? Only thing different was pulled the PCM relay so it would not fire to try and bleed air out of the system... Reservoir is full what do you guys think?
