hpop?
02POWERSTROKE7.3
Alexandria, IN
Im sending a pump to Terminator to have modded to a T500. Im going to rebuild the fuel bowl while its out. Is there anything else i should get or need?
cw96stroker
Central, Texas
Maybe consider just doing regulated return and fuel bowl delete, rather than rebuilding the fuel bowl. If i were going to spend the money in that area, that's what I would do.
neverkickn
AR
I know a guy with a hell of a race truck that still runs the factory fuel bowl. Even if you plan to go with larger sticks soon I would leave the bowl in place. A rr would be a nice addition but bowl delete on a stock truck is a waste of money IMO.
I wouldn't even mess with the orings on the fuel bowl unless they are leaking. The fuel bowl is so easy to get at that I don't see the advantage of doing anything with it that it doesn't need. While you are in a money spending mood you might as well get an oring kit from guzzles for the toolbox in case you spring a leak down the road.
02POWERSTROKE7.3
Alexandria, IN
Well I'm planning on swapping pumps tomorrow hopefully. I also need to change my oil, should I change it while I swap the pump or after I get pumps swapped and running.
neverkickn
AR
Doesn't really matter but since you will be all oily during the swap you might as well do it during.
