Sweet build! Really interested in how far you take those turbos. Keep us updated!
Sent from a Cummins plant, driving a Powerstroke, with a TDI on the side!
:whs: Awesome build man!!!!
On my phone, I cant see the pics. Did you delete the fuel bowl and cooler? Also what are doing on the low pressure side for fuel (sorry if you addressed that in your first post, cant see that right now)?
Awesome build, looks top notch! I'm really excited to tear mine down and do everything you did before my pistons crack or before there is any issues! good luck, and post video's asap!!!
Thanks. Hope to dyno some time in June. When I do that night I'll have numbers posted on this thread.
Since my last post we have been fighting a fuel rail pressure surge. We were using a SCT Livewire and Gearhead was working with us and we just could never get the surge to go away. Morgan Primm suggested as a last dig hope to try an H&S tuner. He found us one and Gearhead sent us tunes for the H&S. It worked perfectly and all the issues we were fighting went away. It was explained to that with the H&S there is a lot more things that can be adjusted. I don't really understand it but honestly I don't need to. It works the way it's suppose to using the H&S. Steve my mechanic buddy doing all the work on it took it out and was telling me at 40 MPH he got into it to about 75% throttle and broke the rear tires loose on the highway. He said it pulls freakin hard and it was super clean so he has to go and check what tune it is running because he wasn't sure but because it's running so clean he didn't think it was the race tune. I'll be going to the shop on Monday June 30th and we'll start working on getting the BOV and wastegate dialed in. Then we'll use a local dyno to set them up the rest of the way. The dyno we are going to use for testing can't load their dyno so I'm not looking to go there for my dyno run that will give me an idea of what it's putting out HP wise. It looks like we are going to be able to make the diesel drags in Spokane, WA on Aug 2nd. Hoping there is a dyno there but no matter what I'll be getting some quarter mile times. Hoping for anything in the 11s. We'll wait and see what it does.
Its amazing that switching programmers with tunes written by same tuner would fix everything. I had always thought SCT offered more tables....obviously I was wrong. Glad to hear that you are getting the bugs worked out and looking forward to hearing the results.
dayum good luck !!!
