HVAC Heater Hose Replacement
AgFisher08
Has anyone had to replace this hose that connects at the back of the EGR and runs down under the ECU? If so any tips? Do I need to drain the coolant?
Mesa, AZ
Yea you’re gonna need to drain the coolant, unless you want to make a mess. Easiest way is to pull the inner fender on the pass side, gives you tons of room to get at the hose. I prefer to pull the tire when o do that, but you don’t have to. If the quick connect is fighting you, take a flat head screw driver and break the little pieces off the hose that capture the white piece.
