Hypermax H2e Turbo
Blowby
66/17 and was setup to run on my tow truck with stage II injectors. Only had it tuned for mileage and interstate towing so it only saw 28-30 psi max. Just pulled it off the truck and opened it up for pictures. No axial or lateral play. Turbo for sale only. $725
Blowby
Drove great! Pulled over I70 and I80 without a problem.
TURTLE
OHIO
Did this spool much better for II's than a stock H2E? Could this support 300/200's?
Blowby
I'm not sure what to post it as! Modded- Non Modded.....
I have researched and found a stock H2e is 62/17.
Looking at the housings I posted what was cast into the housing 66 comp / 17 exh.
I didn't measure the inducer or exducer diameters.
You'll have to ask someone who used larger injectors than my 175's because I can't honestly answer that question.
Oh and price drop to $625!
5ninef250
Measure the compressor wheel yet? My H2E has the "66" on the housing as well, I am always assumed it was the stock 62mm wheel..
Blowby
I did measure and it is a 62mm inducer on the compressor side. I'll have a Mod change the title and first page to reflect this.
Blowby
Since I can't edit the OP I will change it in this post:
62/17 and was setup to run on my tow truck with stage II injectors. Only had it tuned for mileage and interstate towing so it only saw 28-30 psi max. Just pulled it off the truck and opened it up for pictures. No axial or lateral play. Turbo for sale only. $595
