INDIVIDUAL RUNNERS
CRANEMAN
Here are some pics of our new intakes we built in conjuction with ZZ FAB
Hotrodtractor
Mingo, Ohio
Considering these are being mounted onto an already existing P-pumped motor - I would say that something "motorish" is mounted in the valley... LOL
Nice to see you made it over here Roy - I guess you beat me on getting this posted over here.
CRANEMAN
Why is the end of the head not shown in the pictures?
:D
The head is all there. The intake flange actually sticks out over it. There are pieces we machined to bolt to the front of the head that the flange will sit on there so we can bolt that end down.
CRANEMAN
Sweet! More info on the engine?
It has billet rods from Wipe Out Enterprises, JE custom cut and hard anodized pistons. Custom ground cam from TFS Performance. Heads machined for these runners, and machined to accept Jessel roller lifters. Manton pushrods. Custom billet roller rockers. Injection pump and 8.3 cummins injectors from Fair Valley Performance. They are opened up to .120, dual fed bodies, and custom tips. Block is filled and girdled. DT466 valves, pinned valve seats. Heads ported and polished. Block machined for 9/16 head studs. Fire rings. Mallory internally balanced. And we are probably going to dry sump it. Custom 321 stainless log headers and up pipes from Fab Shop Headers. And a custom HX 60 from either Harts Diesel or Robbins Turbo. Thats about it. Ohhh and a dual core, air to water intercooler from Persycon, and it is water injected
jngreen
IN
very nice. This motor goes into HotRodTractor's old red regular cab correct?
CRANEMAN
FYI we will be working on a design for HEUI motors, keep you all up to date
