Obsledpuller
Hey guys I'll be intalling my t4 kit and new plenums in a few weeks and I was wondering what you suggest as far as a sealant for the intake? Is there a gasket or do you just use RTV or something? Thanks
Love my RiffRaff plenums... no sealant needed...
Sent from my DROID RAZR using Tapatalk
i dont think i can use the riff raff since i have the early heads that have 2 less bolts in the plenums. i had to weld two holes in my irate plenums to use them. would love a set of them though.
I just used blue RTV on mine and have had no problems. The grey might be a better option though.
Clay had made some for the obs heads but I don't know if he still offers them or not.
Cometic Gaskets makes an actual gasket for them if you want to go that route.
Have had mine on for around 8 years and max of 65 psi boost and never an issue.
Can't go wrong with the gray stuff, it just sucks when you have to try and remove the intake!
holy chit! are you serious?
No joke brother. Pulled two whole seasons and saw 55+ Psi of boost and haven't had a leak yet.
Nothing more than the fact that I didn't have any other options :lookaround: It was Sunday and I had a pull on Tuesday, and I thought I needed more than one day for it to cure. Looking back I probably should have done it right, but I can sleep at night because I haven't had any problems thus far.
Wow! Did you use a lot of it? Like enough so it gooped up on the inside so it wouldn't push back out?
live life full throttle
