Intake on otherwise stock 15
Platinumtuxedo
Kirkland Washington
Merry Christmas all ya filthy animals!
I did some searching but didn't find what is was looking for. Going to be deleting the truck this year but probably not till summer. I am wondering if anyone has done one of the intakes on an otherwise stock 15. Will it throw a code if it is not tuned? Anything to gain from the intake on a stock truck? No-Limit seems to be the go to for these trucks and that is the direction I am leaning.
Cheers
ncollins64
winchester springs, tn
Maybe check out morgans 2015 test mule build. I think there was quite a bit to gain even on a stock truck with the nolimit intake. I can't remember numbers off the top of my head
ftast350
All I takes work without a tune as long as the sensors are there, you just get more out of them with a tune.
ftast350
That's not true. With dpf on tunes I have a cel all the time with the no-limit 5"
Do you know what is causing the cell?
And I wouldn't think that the afe's or S and B's would be the same since they are designed and tested on stock vehicles (not tuned) at first.
And the NoLimit one is too bad ass not to have a tune!
CATDiezel
The mass air flow circuit doesn't care for the extra air m. Throws a code.
bigrpowr
<How I Fly
Administrator
honestly , I don't think there are any gains on any trucks with a stock tune and aftermarket intake, certainly not worth the money or the effort .
Powerstroked162
On Da Juice
Wa. State
I've never had a light with my intake kit, stock or tuned. Several other vehicles running that configuration as well, with no lights.
I did similar testing to the OP's question. With my cold air intake kit on a stock 15 truck, I saw a 4rwhp gain. The stock intake is more than sufficient for a stock truck. The big gains from my kit showed with power adders installed.
