Is it worth it?
range91
michigan
I am running barder stage 1.5 but still running stock air filter. Is there that much to be had for power with cai or stay with the superior filtering. If its minimal gain or no seat of the pants difference I think I will stick with stock. Any info is appreciated
Dirty_Stroke
Tuscaloosa, Al
I noticed a very noticeable diff with my S&B intake. Throttle response was improved and the 1800-2500rpm range seemed stronger. I was told with any turbo upgrade you should step up to a CAI for improved flow.
FaSSt9602
Gilbert, AZ
You are truly good with the stock system for up to 500hp. I swapped mine only because I got a smoking deal on an Airaid and I was ready for a reusable filter.
